T56 Clutch for sbc 400
Car: Trans Am
Engine: 383 Accel ProRam single plain EFI
Transmission: t-56 Spec #3
Axle/Gears: 4 gen 3.73:1
Hi everybody.
Wich cluch will you recomend for 400 sbc- forged, Dart pro 1 , Lt1 intake, 230/236 roller cam 11.5:1 CR. fidanza alu FW
I had a Spec stage 2 till last saturday, but it is completelly gone. Did 6000 miles on it than i did some donuts, than a hard lunch and.......was gone with the wind.... I need a clutch that will last a bit longer espetially that i will shot 150 NO2 now. I heard Spec stage 3 are hard to operate for normal diving.
thanks
thanks
Car: Trans Am
Re: T56 Clutch for sbc 400
Not jet but don`t have to, during last hard lunch it was so many smoke in and outside the car that i don`t know if i`ve ever made so much durind burnout.
BTW any ideas, were i can buy a replaceble friction disc for fidanza?
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
You need to determine why your clutch failed after 6000 miles before you replace it with another clutch.
Car: 1992 RS Camaro
Engine: 305 soon to be 383
Transmission: Richmond -6
Axle/Gears: 4:10 with Auburn locker
Break in time is vital with a new clutch. Learned this the hard and expensive way years ago. I always thought Spec was good stuff. I'm currently running the Centerforce going on 5 yrs. So far no issues.
Car: Trans Am
this is how it looked like now...... http://imageshack.us/photo/my-images...scf4185hu.jpg/
0 material on the surface of the disc both sides, friction ring from fidanza-scrap, pressure plate have a really deep grooves, like key.....
Night rider327
09-02-2015 04:17 AM
