Currie 9" housing and torque arm problems
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Would have been nice to know that the Strange S-Series iron 9" center section will not fit on a Currie 82-02 housing with torque arm mount. I just randomly mocked it up to clean some stuff off my bench when I noticed this:
The S-Series cases ribs are directly interfering with the torque arm mount. It's the rib between 2 and 3 o'clock:
On the the Pro Iron case I don't think I'll have that issue. I just wish I'd known about this before I bought the center.....According to Currie, they do not know of any center section that does not require clearancing. DAMN! I'm gonna stop by Strange today and mock up a pro iron and see what it looks like.
Car: '82 Z28
Re: Currie 9" housing and Strange center problems
Didn't fit with my factory center section either. I just did a little grinding on the mount and all is good in the world. Looks like you'd have to do a bit too much to make it fit :/
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Back in the day (2002), I had clearanced the mount around the stud, and the rib around the mount.. Didn't want to take too much off of either.. YMMV
Car: '91 LS6/T56/9"
Engine: LS6
Well I clearanced the center today making sure to not leave and sharp points or angles, then the torque arm won't mount with the housing bolted in. HAAAAAAAAAAAAAAAAAAAAAAAAAAA
I'm very familiar the hot-rodding way of making things fit when they weren't supposed to, I'd just like something about the swap to go well....Pics to follow. Gotta catch the fight now.
Car: '82 Z28
The torque arm will mount with the housing in, done it a few times.
xpndbl3, I personally went with Currie because the housing doesn't look like it had mounts that were made from cut offs out of the scrap bin. Currie has factory looking mounts. Yeah there were a few small road blocks but you should really expect that with aftermarket stuff. "Direct bolt-in" is rarely the case for a lot of things.
Engine: 4++,350 & 305 CIs
Im using a moser rear and had to grind a few aluminum case ribs and space the mount out almost 1/8" for clearance. I used this rear because the TQ mount is waaay beefier looking than the currie. On the other hand I like curries factory looking suspension mounts.. If you look at the pic below you'll see (other than the trans fluid covered undercoating) the 2 washers i put between the TQmount and housing.. And yes thats a 4th gen V6 rear swaybar. I use it on the street. I remove the front bar and install the factory 3rdgen WS6 rear bar when I hit the 1/4...
Car: '91 LS6/T56/9"
Engine: LS6
Man I've ****ing had it with this Currie housing. The torque arm mount ISN'T EVEN CLOSE!!!!! I've a Jegster adjustable torque arm, and here is it new on my stock 10 bolt. Notice the proper fit and clearance all around?!?!:
Here it is today with the Currie 9":
WTF is going on?!?
WTF is going on?!?
Car: '91 LS6/T56/9"
Engine: LS6
Because I found a housing/center/axles/brakes local and affordable. Got a detroit locker and 4.57 gears for under $320 combined, so I was looking pretty good........................until all this **** started happening!
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Currie 9" housing and torque arm problems
that all blows.
if it makes you feel any better, the jegster TA mount on my stock 10bolt didnt clear the floor for **** either, so i made a different mount and tossed the jegster one in the scrap heap.
is you currie housing centered in the car in that pic?
Car: '91 LS6/T56/9"
Engine: LS6
See but the Jegster sit fine with my stock rear, so I've no idea what's going on! I've searched and searched and haven't found anyone with an issue like this yet!!!!
I just want to drive my car!!! Setting up the 3rd member was tomorrow, but not till this is sorted out. I can't even begin to imagine how this can be fixed.......
Car: '91 LS6/T56/9"
Engine: LS6
Here's some with the bare center on:
For what it's worth, there are fitment issues all around. A Dana 44 and a BMR adjustable torque arm make contact with the tunnel right at the forward bolt mount. (Actually punched a hole in the floor on a deep compression). I had to add about 3/8" rear axle bias towards the passenger side for a little more clearence.
Car: '91 LS6/T56/9"
Engine: LS6
I could deal with buying an adj panhard bar for a 3/8" adjustment..........but I'm looking at 3-4"!!!! Somethings got to be wrong here! Someone please tell me I'm going something wrong here.....
Car: '91 LS6/T56/9"
Engine: LS6
Will an adjustable bar adjust that far?
edit: I dropped the panhard bar just to see how much movement the housing has side to side, and it's only 1.5" max.........not nearly enough. wtf do I do now?
I know that I have totally different components moser 9"/spohn tq arm,but the spohn tq arm has two sets of holes one set for stock application's and one set an inch over just for 9" housings,this may be part of your problem. Even with that I still needed to grind tq arm bracket and mallet massage the underbody for total unobstructed suspension travel. Also pull out your coil springs so you can see if you have clearance upon full compression of the rear suspension when you get your current issues rectified. I didn't understand how I picked the car off the jack stands without hitting the bump stops but it was the tq arm bracket hitting and picking up the car.
It almost looks like you could flip the mount over, cut and move the TQ arm box w cross bolts down..
Car: '91 LS6/T56/9"
Engine: LS6
Car: '91 LS6/T56/9"
Engine: LS6
A kind third gen owner sent me this.........exactly what It should look like! Notice how the torque arm faces directly in front of the mount/bolts! Exactly what I'll be doing. Thanks Derrick!
Car: '91 LS6/T56/9"
Engine: LS6
So after a full Saturday of work, here's what I've some up with. I fabricated a 1/4" torque arm bracket that relocated the arms position aprox 3" to the passenger side. I set up my pinion preload so that I'd be able to mock up the center section on the housing and design around the yoke.
there is some extra material on that you can trim off when its welded up, but it looks like a step in the right direction to me!
Car: '91 LS6/T56/9"
Engine: LS6
The torque arm is for sale now btw, but not listed in the classifieds yet. $250. Includes the custom mount, arm, tunnel plate, bolts. $250
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Seriously curious why none of you are just taking a big hammer to the offending bits of the floor pan?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Currie is in my back yard and I'm here to tell you they suck.
Nasty attitude.
I went with a Strange 12 bolt, dropped right in and hooked up like stock.
After talking to them I made up my mind, it was an easy choice.
Nasty attitude.
Car: '91 LS6/T56/9"
Engine: LS6
Well Strange Engineering is literally half a mile from MY house!
ambainb
04-25-2016 09:21 PM
Thirdgen89GTA
08-20-2015 03:11 PM
