Whining noise from Rear Trans am
I am using the OEM 1984 Trans am 10 bolt rear, 3.73 rear ratio with Richmond locker a T5 trans and a aluminum GM drive shaft.
Don't know if the ring and pinion are original or have been replaced (say with a noisy Richmond gear setup) but it is using the factory ratio.
So here the deal - no rear end whine while accelerating, no rear end whine while decelerating. No rear end whine while coasting in neutral.
However, there is a significant whine between 40 and 50mph then above it becomes much quieter only with a very light load on the gas pedal as if to maintain constant speed.
There is not a lot of sound insulation in my car. Therefore the noise sounds pretty pronounced to me I think it is coming from the rear end.
About a month ago I drained and refilled the rear diff with fresh lube till it ran out the fill hole. Noise is the same and the fluid was clean with no visible metal. I was told it was fresh when I bought the car about a year ago. There are no leaks around the pinion and I am fairly sure the rear was rebuilt when the locker was put in.
One side note when I had a steel drive shaft the noise seemed to be about 55mph at least that's what I remember now with aluminum I hear it mostly at 45mph.
Any other suggestions?
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
Re: Whining noise from Rear Trans am
i have a 84 z28 that i bought from my gran mother that does the same thing and she took it to the dealer a couple times when new for this and they said it was how they all were . Don't know if that is 100% true but it's done it since new and has never had a problem aside from that noise .
It's not how they all were. Sounds like you've got a problem that will eventually get worse. I tried installing a richmond set in mine, couldn't get a good lash setting on it, whenever they'd blue the gears to mesh them, they'd never match up right. Got a set out of a junked car, ran quiet, just like my originals. I'd definitely have it looked at before it goes.
Well i think I have the factory gears. I was told they are 3.73 and I have the RPO codes for the L69 with the 3.73 rear end.
The other thing it might be is the poly bushings I should probably lube them again. I remember in the last car I had all rear poly stuff it squeaked a lot. I guess I will have to pull the rear diff cover and take a look this winter.
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
do you have any aftermarket rear suspension mods?? I have a crossmember torque arm, and from that day I have had a little whine around 45-50 mph. I have swapped the gears, and same noise. Called the company, and they told me that they transfer vibration much easier than the stock torque arm with rubber bushing and attached to the transmission
Winter is here I may be able to get on a lift so I thought I would bump this for more opinions.
So to review
lowered 2 inches intrax springs
poly bushings on rear control arms
poly engine and trans mount
Gen 4 aluminum drive shaft or steel both make sound
10 bolt 3.73 GT4 with Richmond locker
So to review
So to review
So to review
^ do you remember what it cost to have it replaced?
Yeah, parts and labor was right around $700, but I'm here in England and prices are retarded high. When I just had the pinion replaced back in 2005 in Texas, I want to say it was around $400-$500 for parts and labor. That $80-$90.00 per hour labor rate really catches up quick.
Engine: 4++,350 & 305 CIs
Wow thats pricey 4 rearend work.
I charge 250$ labor for a complete rebuild with or without gear/ diff swap.
I was thinking I am lowered 2 inches with the factory panhard bar. So you think the rear being misaligned could cause some noise? Maybe pushing on something poly?
The wine will have nothing to do with poly bushings. My car is lowered as well and it is possible that this is causing the issue. You'll need to get the lower control arm relocation brackets to fix this. I still believe your rear is bad and needs to be rebuilt. Get the relocations brackets, the company that repairs the rear should be able to mount those for you as well. I know Spohn, Hawks and I think UMI sells them for our cars.
theshackle
09-17-2020 08:26 AM
