Lakewood Bellhousing, need adj pivot?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I have a Lakewood bellhousing on my car and was wondering if an adjustable clutch fork pivot was needed or not? Tranny is a tko600. Anybody have to change the one that Lakewood supplies on it? I would rather know now instead of having to tear it apart again.
Car: 85 Iroc-Z
Re: Lakewood Bellhousing, need adj pivot?
Also, can the stock clutch fork be reused?
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
How did it work out for you? I just got done my TKO install with that bellhousing and now cant get the car into gear
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
i used the adjustable pivot with my lakewood bell and tko. I believe its adjusted almost all the way out? its been a while since i put it together. Never tried the stock pivot, since i never had one.
Car: 85 Iroc-Z
I just kept the pivot that came on the bellhousing on it. I haven't driven the car yet, but when its running, it goes into gear fine. Did you install your throwout bearing correctly?
i just put this bellhousing in and triple checked the bellhousing runout which was within specifications.
you WILL need an adjustable clutch fork pivot and use the stock clutch fork wich works great......are you using an adapter plate for the tko?
Car: 85 Iroc-Z
I am using the adapter plate. How do you know how much to adjust the pivot?
Car: 85 Iroc-Z
What would be the disadvantage of the Lakewood one being shorter? Wouldn't that be a good thing as the clutch will have further travel?
Car: 85 Iroc-Z
So do I just install the adjustable one and adjust it all the way out?
15020, 86, adjustment, arm, bellhousing, camaro, clutch, fork, gen, index, lakewood, pivot, release, suspension, tko600
