Mysterious Transmission fluid leak
1 Post
Car: 86 Firebird SE
Engine: 2.8L
Ok I am ripping my damn hair out over this one. I have a 1986 V6 automatic Firebird and the goddamn transmission is pissing fluid out of somewhere. Thought it was the pan gasket so I replaced it(The gasket was dried out and cracking). Thought that solved the problem but the F@#$%n leak is still there and I checked the cooler lines and they are dry, the front pump seal does not appear to be the culprit as its dry in the front area, the tailshaft seal is dry so I don't know WTF else to check. If it is the front pump seal, I'm junking the car as I'm not paying all that money to fix the damn transmission.(I dont have it anyway, I have 2 kids and a house to pay for) I could buy another car for that amount. I inherited this car from my late father but if its going to nickel and dime me like that, it's gone. I'll go back to running $500 pieces of crap. When it blows up, pull the plate off of it and buy another turd.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Mysterious Transmission fluid leak
a possibly stupid question, but where is the fluid leaking from? If its leaking, it should be pretty clear where its coming from, or at least what end of the trans.
is it coming out of the inspection cover, running down the side, front back middle, ect?
1 Post
Car: 86 Firebird SE
Engine: 2.8L
It is all over the crossmember and blowing back towards the rear. It's hard to pinpoint where exactly. It's just coming out and leaving a decent sized puddle on the ground after I shut the car off.
Car: 89 chevy camaro rs
bet i know...lol check the vacum vent on top of tranny,it blows fluid out if theres to much presure or to much fluid or over heating
1 Post
Car: 1989 Camaro RS--
Engine: MPFI
I know you fixed the tranny seal, but if not done right, they can still leak. I know it is such a pain in the A**, to be dealing with constant car problems. Best thing to do with these cars is to always fix them right the first time. Not saying you didn't. Hey there is only a few places the tranny can leak.
1 Post
Car: 86 Firebird SE
Engine: 2.8L
The trans pan is not leaking.
Car: '82 Z28
Clean the **** out of it, take it down the street and back, crawl under it again and see where it's wet. One thing I ran into was the dipstick tube had cracked and it made a huge mess, just another thing to look for.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Have had leaky speedo cables, and TV cables, along w/o-ring on dipstik....
no consideration of my comment?vent is dead center on top of trans right around the middle(little plastic tube)
Your leak could be coming out of the rear of the driveshaft yoke. There is a seal (large o-ring) inside of the transmission that fits against the yoke to prevent the fluid from going by the splines and out of the weep hole at the end of the yoke. Otherwise wipe down the transmission completely, come back in a an hour and use a white paper towel and find the leak.
someone972
08-30-2015 12:52 AM
