Strengthening a 10bolt
Car: '84 Z 28
Engine: has 8 cylinders
Transmission: has a stick coming out of it
Axle/Gears: a grenade, makes wheels turn
http://www.camaroz28.com/forums/show...ghlight=10bolt
found this on camaroZ28.com while surfing for tips tricks, just like a lot of others I dont have $3k to drop on a 12bolt or 9" rearend.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Strengthening a 10bolt
That's a very old link to beefing up a 10 bolt. After spending close to $1000 to make it stronger, you still have the tiny ring and pinion teeth which will break before anything else does. For a little more money, you can buy a 9" housing package and install a junkyard third member and be better off than wasting money trying to patch a weak diff.
The 10 bolt can still take a lot of abuse. My BBC punished one on the dragstrip into the 11's before I installed a 9" however they've also been broken in a factory street car. Even after spending money trying to beef it up, you're still rolling the dice on something that will still fail.
A $3000 replacement diff is a complete, ready to bolt in, doesn't need anything else package. You can easily do it cheaper if you don't want all the best aftermarket parts on it. $1000 will buy you a 9" housing package with axles. Install your OEM brakes and drop in a junkyard center section and you're ready to go. You can upgrade stuff like brakes, posi, gears etc as funds permit later on.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
You could try one of these = http://www.jegs.com/i/L.P.W./619/301-7.5G/10002/-1
That way your not spending allot of money yet your getting about as much support as you can give a 10 bolt.
I have one.
Heres a link to L.P.W's home page.= http://www.lpwracing.com/
I have one.
Engine: gone
Transmission: gone
Axle/Gears: gone
Yup do the mod RONUS suggested. beefy aftermarket gears. keep up on your fluids. and hope for the best!
MrDude_1
07-28-2004 12:58 PM
TAMECH
02-18-2002 12:40 PM
10, aftermarket, axle, beef, beefing, bolt, camaroz28com, gen, oem, posi, strengthen, strengthened, strengthening, t56, thurd
