700r4 street & strip --- help
Car: IROC-Z
Engine: 377
hi guyz
im going to change Clutches in my iroc-z
so
any body know about good brand and cheap
im talking about 500hp
thanx
so
thanx
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Re: 700r4 street & strip --- help
Go to https://www.700r4l60e.com/store/prod...&cat=19&page=1 This will give you all you need to build it for 500FWHP. Dana
Received 1,811 Likes
The ones you linked to in your other post, the Alto "Red Eagle", are a good one.
You'd need the entire kit though.
Plus, for that transmission to survive behind high power, there are other parts that need some attention, besides just the "kit". "The Beast" sun shell, a Transgo shift kit, Corvette or similar servo, are a few common upgrades that make a BIG difference to both performance and longevity.
And of course, having somebody build it that is familiar with it in detail and knows EXCATLY what to do, is a HUGE help as well.
Being where you are, you might want to consider buying a whole, ready-to-install transmission, rather than trying to piece it together. Dana at ProBuilt, PATC, and a few others, are good places to start looking for that.
Car: 1988 Iroc Z
Engine: SBC 355 crate motor
Transmission: T56 6-speed
Axle/Gears: 7.5 stock Disc rear.
If you are interested i have a built 700r4 for $1000. about 1000mi since rebuild, transgo shift kit, corvette servo, eagle clutches, heavy duty sprags, HD 2000-2600 stall converter, full throttle valve added. I intended on using it for a 500hp crate motor and the shop that built it told me it should have no problem handling it.
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
They have a nice parts megastore and shipp out quickly, but I would not buy another assembled transmission from them.
https://www.thirdgen.org/forums/tran...level-3-a.html
https://www.thirdgen.org/forums/tran...uck-patcs.html
Car: IROC-Z
Engine: 377
thainx guys
i already have transgo stage 2-3 (i did not fix it yet)
so i think better i go with red eagle
Car: IROC-Z
Engine: 377
dear im in bahrain I guess the shipping will be 500$
Car: 1988 Iroc Z
probably more than that
Mongoose462ci
09-16-2015 11:46 PM
