t-5 noise?
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
t-5 noise?
My t-5 trans, non world class, makes a noise only in neutral, with the clutch engaged. It sounds like a "rock tumbler", and if you push in the clutch, its gone. Sound like an input shaft bearing? ANY INPUT APPRECIATED
Re: t-5 noise?
No; just, the moving parts of the trans spinning around in there.
All manual transmissions do it to some extent.
If it doesn't whine too bad when loaded, ignore it.
Re: t-5 noise?
Thanks. Ive heard its common on t-5s, and others have said its an input shaft bearing problem. My t-5 is quiet down the road, just has the "tumbler" sound in neutral
Car: 1991 Camaro RS ttops
Engine: 00 383
Transmission: t-5
Axle/Gears: moser 9" 3.50
Re: t-5 noise?
mine whines. and when i push the pedal in it goes away? everything is new but it behind a pretty strong motor. could it be a throw out bearing?
sjorgens
10-01-2015 08:54 PM
