Short Spring Syndrome
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Been having some issues with my car and I think that I have narrowed it down to what they call short spring syndrome. Couple things. First has anyone else ever experienced this? To replace the spring, what is involved? I know I have to drop the pan and remove the TV plunger, but what else? The last thing, where do I get that spring from, where can I order one?
Received 1,839 Likes
Re: Short Spring Syndrome
I think what you're looking for might be this...
http://www.sonnax.com/product-lines/...ion/parts/1611
You might try here http://www.transmissionpartsusa.com/...rts_s/5532.htm
or here http://www.oregonperformancetransmis...y_Code=2004RHP
Car: 86 IROC
Axle/Gears: BW 3.27
Took a look at the sites. Is the only thing that I need to replace is the spring, or do I also have to ream the bore and replace all the parts? Or is that something that I have to see when I open it up? Is it possible to change the spring without removing the valve body?
Hard to say... that bore in the valve body supposedly wears over time and is farkled in ALOT of em, so it might need both.
But it's not that tough to try just the spring, and then if it seems like it needs the whole valve & reamer and all that, go back and re-do it.
Car: 86 IROC
Axle/Gears: BW 3.27
Perfect. Looks like I have a little project once the car comes out. Thanks
wigmobile
09-17-2015 03:38 PM
