Is this common with camaro trans
Engine: 5.0 tbi
I just got my camaro last week got it home got it running and on the road driving to work for the first time in the morning. On my first test run i noticed the shifter bouncing so i took it home and replaced a bad trany mount and checked the motor mounts and it is still doing it just not nearly as bad it seems to be doing it when the rear wheels hit a bump could this be because of the metal rail that runs along the drive line and connects the trany and the rear end? dont know what its called
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
re: Is this common with camaro trans
It's called a torque arm.
Sorry - I don't have any good answers for you other than the obvious - get under the car and see what else is an issue.
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
Mine bounces a lot. dont know if it's supposed to or not but it has for the last 2 yrs and all the mounts are good, so I don't really have an answer lol other than me to
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
all the bushings are rubber, i assume the trans is the t5? manual trans?
a littel movement in the shifter is normal, it is connected to the trans, and the trans will move with the engine and the torque of the torque arm.
Engine: 5.0 tbi
Re: Is this common with camaro trans
[quote=//<86TA>\\;4858521]all the bushings are rubber, i assume the trans is the t5? manual trans?
Yes it is a manual trans. As for it being a t5 i have no clue only owned the car for 6 days. any threads i can read that may help me figure out what my trany is?
And thanks to all of you appreciate the help and knowing that it is doing it in other peoples camaros is a relief
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
