is a 3600 stall tq converter too much?
Old 02-14-2011 | 02:13 PM
86IROCracer89's Avatar
Car: 86 IROC-Z
Transmission: 700r4 3000stall
im trying to figure out what a good stall would be for me. i have a crate 350 with trickflow heads and a fully ported edelbrock TPI intake. i run the motor to about 5600-5700. ive been looking at the ss3600 from yank but wondering if its possible to overdo it. ive driven my cousins ls1 with a 3600 in town and the drivability isnt that much different to me so im not worried about that.
Old 02-14-2011 | 02:45 PM
Re: is a 3600 stall tq converter too much?
That's probably too much for a TPI 350 motor. It's beyond the torque peak RPM of the intake system.
Something in the high 2000's is about where you want to be; 2600-2800 or so.
Old 02-14-2011 | 02:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Agree, stick to 2800 or so..3000 MAX
Old 02-14-2011 | 03:43 PM
Car: 86 IROC-Z
ok so does anybody have any opinions on tci streetfighter tq's?
Old 02-14-2011 | 10:35 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Vigilante 2600-3000 stall. You'll be happy.
Old 02-15-2011 | 01:11 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
What's the camshaft specs? That will determine where the stall speed should be.
Old 02-15-2011 | 01:36 AM
Car: 86 IROC-Z
only 450in 460ex
Old 02-15-2011 | 08:08 AM
AlkyIROC's Avatar
Car: 87 IROC L98
That's only the lift. What are the rest of the cam specs.
Old 02-15-2011 | 10:02 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
duration at .050 with those lift #'s are around 220-228 range normally eh?
Old 02-15-2011 | 04:29 PM
Car: 86 IROC-Z
yea duration is 222 on both ends was ready for bed and wasnt thinking when i posted the lift lsa is 112 if that matters to you at all
Old 02-15-2011 | 04:43 PM
EvilCartman's Avatar
Car: '82 Z28
Call the converter company and they'll recommend or build you one.
Old 02-15-2011 | 09:58 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
basically. call precision industries the makers of vigilante. they'll make you one and if you dont like it you can change the stall one time for free in the 1st year I believe.
Old 02-16-2011 | 05:17 AM
Pro Built Automatics's Avatar
I have been a distributor for the the Vigilante for over 15 years now. They are an excellent torque converter as most here already know. The cam specs at .050" lift, the lobe centerline, rear end gear ratio, daily driver or weekend warrior, any plans of nitrous, and how you drive, conservative? moderate? moderately aggressive, or aggressive? All of this will determine what the stall should be. Stay the hell away from TCI. I have seen many of these TC's eat the transmissions they were in front of, same with B&M.
Old 02-16-2011 | 12:54 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Peak torque will be in the 3400-3600 rpm range with strong curve from 3000 to 3800. I'd stay 2800-3000 is best for TPI's power band. Your only gonna run to 5500 rpm shifts with peak in the 5000-5200 range at best.
Hotrodboba400
12-10-2019 08:07 PM
customblackbird
10-01-2015 05:30 PM
amcnellis
09-16-2015 05:16 PM
blackandblue02
09-10-2015 09:19 PM
Hotrodboba400
09-02-2015 08:28 PM
