Kickdown Cable Length for 82 T/A Crossfire with TH350?
Car: 84 Trans Am
Engine: V8 305 4bbl
I am swapping in a Turbo 350 to my 82 Crossfire T/A. I've searched high and low...can anyone tell me the proper length kickdown cable to get?
Thanks,
Joe
Thanks,
Joe
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: Kickdown Cable Length for 82 T/A Crossfire with TH350?
I am not sure what length, but the one I uses is out of a 75ish camaro. The exact year depends on what year your th350 is. They used a fat or a skinny end on the trans side where the cable connects to the rod of the trans. Hope that helps some.
Car: 83 berlinetta
Engine: 305 roller motor
Transmission: th350
Axle/Gears: 10 bolt 3.08
B&M makes a universal one where the length is ajustable you can find them on summit in the trans and drivetrain section.
Car: 84 Trans Am
Engine: V8 305 4bbl
Awesome, I will check that out. My 350 is from a 1974...it's the final piece of the puzzle...Thanks!
Joe
Joe
TMZIrocZ350
10-07-2015 12:09 PM
