Rear End Question
Old 02-05-2011 | 06:52 PM
southern muscle's Avatar
Rear End Question
Hello all,
I was under my car yesterday and noticed a considerable amount of "thickened oil" across the floor pan where the drive shaft meets the read end. Its hard but is gooey (haha im sorry im just trying to be descriptive) It seems like there is a leak, and while the car drives it spits the oil across the floorpan. Could this be all the rear end oil? If so what gaskets could have went?
I don't know much about rear ends so if all that sounded out of whack I apologize in advance.
thanks for any feedback.
Old 02-05-2011 | 07:05 PM
vjgillespie's Avatar
Car: !991 RS Camaro
Axle/Gears: 4.10 4th gen
Re: Rear End Question
Sounds like the front seal (pinion seal) on the rear end. Its only like a 7 dollar part but you have to take alot apart to fix. Might be able to drop driveshaft, remove pinion nut and the rear yoke only but I'm not positive on that. If that won't work the whole rear end has to come apart.
Old 02-05-2011 | 07:08 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. Here's a how-to:
https://www.thirdgen.org/forums/tran...ring-seal.html
JamesC
Old 02-05-2011 | 11:31 PM
big gear head's Avatar
Most of the time something that thick is coming from the U joint. Be sure that the oil is coming from the rear end and not the u joint before you start taking things apart.
Old 02-05-2011 | 11:35 PM
wow thanks for the replies guys.
I will jack it up on monday and take a better look around. I am hoping now that it is the u joint, would be an easier fix eh?
Old 02-05-2011 | 11:54 PM
If it's the u joint then there is probably nothing to fix. They tend to sling the excess grease out of them.
Old 02-06-2011 | 08:36 AM
there is a considerable amount though. Today driving to work, around 75 mph the car has a small shake to it that feels like its coming from the drivetrain from the end of the trans back. I am no mechanic but that's what it seemed like.
Old 02-06-2011 | 04:55 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
It's sounds like a u joint. Much easier and cheaper to replace if you have a vice big enough or press.
Old 02-06-2011 | 05:33 PM
suks2bu37's Avatar
Car: 1983 Pontiac Trans Am Daytona Pace
Engine: 305 Crossfire injected
Transmission: 700R4 with shift kit
Yep, sounds like a good old u-joint. The u-joint seals have hardened and allowed the grease to sling out. Noe the needle bearings are going. Cheap and easy fix though!!!
Old 02-06-2011 | 10:20 PM
Alright tomorrows the day. I have off all day so I'll be able to jack her up and get this hopefully resolved. I have put so much dang money into this camaro, everything is going to be new eventually! haha, good ole old muscle cars you gotta love'm
hectre13
12-11-2023 09:14 AM
TreDeClaw
Theoretical and Street Racing
06-22-2021 09:21 PM
hectre13
08-26-2015 09:17 AM
AkDrifted
08-17-2015 08:45 PM
BlackBoulder
08-12-2015 12:15 AM
