VSS question
VSS question
I am in the middle of swapping my motor and tranny from my 85 to my 84. It has a cable driven spedo in both cars but the 85 has a vss buffer under the dash. Since it is cable driven it doesn't use a VSS correct?
Re: VSS question
The vss buffer on the 85 was under the dash on the passenger side nothing on the speedo i looked in the same place on the 84 and have not seen one so it must be on the back of the cluster. so the tranny has a vss sensor as well?
Re: VSS question
Are we discussing Camaros or Birds? On Camaros, the VSS is located on the rear of the cluster 82-89 (a small yellow box). The cruise control module is found on the pass side (the 84 may have had a transducer. Check the cable under the hood). 90+ has the VSS on the trans tail shaft.
JamesC
JamesC
