T56 2piece rear main flywheel
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Transmission: T-56 fully built WOOHOO
I noticed there are a few different centerforce part numbers which one do I need I have a 69 350 block with a 400 crank it's a 383 I'm not sure how it was balanced when built I got it used for free any help?
Received 1,839 Likes
Re: T56 2piece rear main flywheel
Gotta know how it's balanced.
If it's the stock 400 balance it'll need one FW; if it's the 305/350 balance it'll need another. Without knowing how your motor is balanced, no way I (or anyone else) can tell you which one you need. We'd have basically a 50/50 shot.
You might look at what's on it now and get the same type setup, if the current one doesn't vibe.
Engine: 5.7tpi 350,
So I have the harmonic balancer is on it as well as the original flexplate as it came is there a way of telling based off that?
If the original flex plate ran right, without vibes, then whatever balance that has, is the flywheel you should buy.
Hopefully it hasn't been "custom" hacked on, a common BAD thing that happens when people screw up and allow their damper and flex plate or flywheel to EXIST in the same shop at the same time with their rotating assy.
1 Post
Car: 92 RS
Engine: 383 FIRST TPI OBDII DBW
Axle/Gears: 3.73 POSI DISK
If the flex plate has weights then its externally balance or if completely smooth on both sides its internally balance
ambainb
04-25-2016 09:21 PM
LT1Formula
08-20-2015 09:36 PM
