700r4 rebuild
700r4 rebuild
My son and I are rebuilding the 700r4 for his 86 z. What I would like to know is what is the best rebuild kit to use? Any advice on specific parts I should use? Basically what parts do I need ?
Re: 700r4 rebuild
Go to https://www.700r4l60e.com/store/home.php?cat=19 This will give you the choices you need here. Let me know if I can be of help? Dana
Re: 700r4 rebuild
Re: 700r4 rebuild
I'm looking to spend around $300. I've already dissassembled it. Whoever rebuilt it before didn't have any springs for the accumulator, they just had some nuts in there for spacers and the seperator plate was bent from that. So I also need the accumulator springs and seperator plate and the spring for the servos was missing as well. and I bent the retaining ring for the 1st/rev apply piston. additionally I would like to put a shift kit in it.
Re: 700r4 rebuild
something like this but you need to check the correct application
http://www.summitracing.com/parts/TC...Make|CHEVROLET
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Re: 700r4 rebuild
If you need all those additional parts check out WITTRANS.com You can about have a transmission shipped to your door as individual parts. I just did a transmission for a guy and needed to buy that same spring (~$7 I think). They also offer all the accumulator springs, be ready to do your homework because there are a few to choose from. However if you buy a shift-kit it may come with the ones you need so look at that as well.
Re: 700r4 rebuild
I ordered a rebuild kit from this place: http://www.transmissioncenter.net/hi...00r4.htm#Parts
I ordered the rebuild kit,shift kit,seperator plate and all the springs that I need. $280 shipped
1 Post
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: 700r4 rebuild
If you are going to put any power in front of the trans I would look into upgrading the core you are starting with. I believe the '86 version doesn't have the aux. valve body that was added in '87 or '88 and was a major upgrade for these trannys.
3.8TransAM
09-27-2015 08:37 PM
Dragonsys
09-25-2015 03:51 PM
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
