shift kit question?
Old 11-20-2010 | 08:40 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
shift kit question?
ok so i swapped a 700r4 into my 91 305 RS, the tranny came out of a s10 with a 350 and thats about all i know about it, ive been driving on it for 2 days now and it seems to hang out in the gears for a while it shifts kinda hard but very smooth if that makes any sense it doesnt make any noise nor does it slip, im wondering if maybe it has a shift kit?? ive never driven a car with a shift kit so im not sure but everything ive heard about them fits this category.. any replys would be helpful input. thank you!
Old 11-21-2010 | 03:47 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Re: shift kit question?
any takers? someones gotta know something here.
Old 11-21-2010 | 04:35 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
theres really no way of knowing without tearing into the tranny and checking out the valve body.. make sure your TV cable is properly adjusted.
Old 11-22-2010 | 05:53 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
i thought that was self adjusting? im a newb at auto trannys i just unbolted unplugged and unhooked/ then rehooked plugged bolted and added fluid... would this have anything to do with my car making me nervous about stalling when i come to a complete stop or after a quick rev or when i put it in park?
Old 11-22-2010 | 06:01 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
also i measured the old tv cable from the mount behind the TB to the end of the cable clip and they're the same length... how would i go about adjusting this do you know? also that TV cable does not allow me to open my butterflies all the way and puts a lot of tension on my peddle as well did the old one.
Old 11-22-2010 | 06:07 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
well heres a few links to look at http://www.tvmadeez.com/article/index.php
http://www.tciauto.com/Products/Inst...ble_adjust.htm
Old 11-22-2010 | 06:11 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
thanks bro, ill look over these and reply back once i come to a conclusion.
Old 11-22-2010 | 06:16 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
it really sounds to me like you have gotten ahold of a wrong cable someplace along the line... i had the same thing happen
Old 11-22-2010 | 06:43 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
what do you mean by wrong cable? improper length?
Old 11-22-2010 | 09:47 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
yeah its def the wrong cable if its not letting you go full throttle or there is somethig wrong in the valve body
Old 11-22-2010 | 10:37 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
well i got it all situated thank you so much for that link i got it set right and it wasnt hard however i did end up breaking the plastic casing that our gas peddle sits in that gives it lever action i had to apoxy it back together for now looks like ill be making a trip to the junk yard this week lol
Old 11-22-2010 | 11:24 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
not a problem man i hope it takes care of your problems
Old 11-23-2010 | 07:22 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
yeah definitely did. one more question its off topic but just want to get your opinion while the tranny was out i replaced the air stock air breather with a holley classic chrome breather and i also changed my wires since one of mine got melted on the header..
with that being said my car seems to not like to idle it stalls very occasionally when i come to a complete stop put it in park but it always tries to catch itself and is usually successful. now when im sitting at idle in gear the car seems slightly rough did i maybe bump my ignition timing off? it was 100% fine before i did these changes.
Old 11-24-2010 | 12:57 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
When you went to the aftermarket breather did you install the intake air temp sensor back into the filter houseing?.. im thinking thats where the factory one is for the 305 tbi its been prolly 5 years since i did away with it. Also you might wanna take the idle air control motor out of the throttle body and be sure its not carboned up at all.. even though it was working fine with the other setup...
Old 11-24-2010 | 11:28 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
good call ill check that out aswell im thinking that since it said for a week the fuel filter clogged up im going to change that next. i attempted that tonight but just ended up spilling gas everywhere.
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
italiano67
12-11-2016 09:21 AM
crazynights
08-21-2015 06:53 AM
TreDeClaw
08-14-2015 06:58 PM
dhonda200
08-11-2015 11:50 PM
Quick Reply: shift kit question?
