383 to 6spd trans questions.
Car: 1982 z28
Engine: 383
Transmission: 4l60e
Axle/Gears: 3.73 posi
ok i had bought another camaro but this one is a 5spd car which has no motor or transmission and i have a 383 with a 2 pc rear main and im wanting to go with a 6spd in this car over the auto i have on the back of the motor now. now the car had come with a 4th gen hydralic clutch asm, i know ill need a fly wheel with an external balance fly wheel for the 400 crank thats in my motor. my question is i plan to look for a lt1 6spd transmission whats the best fly wheel and clutch asm should i go with and being a lt1 6spd do i need a cltuch asm for the lt1 or can i go with the ones as5spd camaro clutch will the 3 gen cltuch pedals work with the 4th gen clutch and hydralics, what ever help or ideas u guys have would be great thanks.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Re: 383 to 6spd trans questions.
I have everything you need. Two piece external balanced flywheel, clutch, trans, shifter, crossmember. Everything to do the swap for 1500.00 us.
Car: 1982 z28
Engine: 383
Transmission: 4l60e
trust me it sounds very tempting but right now money is tight, im just goin and try and get things little at a time. just would like to know what will work with a t56 trans on a older motor.
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
