700r4 tranny governor
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: 700r4 tranny governor
WTF? It probably wouldn't shift and burn up??WTF would you do that for?
Put a governor w/ heavier weights in it, your tv cable may be too tight also? I'd go w/ heavier wieghts... Has the trans. been modified?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The 1-2 is normally a little later than you'd expect, just from the ratio drop.
well it was like that b4 i put it in there. and i dont think it should change untile it redlines 7000 RPMs and it will only change if u get it and it hits that 7000 RPM
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
