View Poll Results: Gears
New 3.73's with posi unit
100.00%
Just get posi unit for the 3.23's
0%
Voters: 4. You may not vote on this poll
3.23's or 3.73's
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
3.23's or 3.73's
So I was going to get a 3.73 rear gears for my car. I finaly took off the rear cover and found out I have 3.23's already it stamped (well can't remember the. 4 number but I divided them and it came out to like 3.21 or something around there) and 7 5/8 ring gear. I want to use this car as street/strip. So give me your opion do I A. Get new 3.73's or b. just get a posi unit for my 3.23's.
Thanks Tom
Thanks Tom
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 3.23's or 3.73's
Choosing a ratio has to match the rpm range of the engine, and the usage of the car. If you're doing a city build with a 5500+ rpm cam and good aftermarket heads, do the 3.73s. If it's a highway cruiser for long trips, with a torque cam and ported stock heads, then keep the 3.23s.
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
KO1
16
10-15-2015 05:00 PM
UltRoadWarrior9
09-02-2015 08:24 PM
