9 bolt bw upgrade
Car: 1989 iroc z
Axle/Gears: 9bolt/3.45
9 bolt bw upgrade
Ive got 2.77 gears in my 89 iroc and i'm going to upgrade. will i be happy with 3.27 or should i go 3.7? Then do i rebuild tranny (700r4) and add shift kit, everything else is tight on the car as far as im concearned so this is where im putting my money. L98 J65 GH3 G80 just a few codes for an idea of what im working with - still waiting on a call from 9bolt.com im about to just order the 3 series carrier and gears but i really want some info. thanx in advance
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
Re: 9 bolt bw upgrade
You will LOVE a 3.70 and an A4 under your car. The feel of the pull is night and day. Only draw back is the MPG, but if you're not too worried about it, then you would do best by going higher than 3.27. I got 17-19 on the HWY with my 700R4 and Richmond 3.73's. I had a 10 bolt, of course; same difference.
Car: 1989 iroc z
3.70 it is! This car isnt going on family trips so gas mileage wont upset me, im goin all out on the axle and tranny so lookin for any advice on special upgrades - i finaly bought my highschool dream car haha!!
As you will find out by reading up on both the 10 bolt and 9 bolt, they aren't the strongest things out there. They will break under tons of torque and power. If you're planning on really upgrading your engine and you end up putting down a few hundred ponies, then your rear will be the first to go. If I were you, I wouldn't bother spending more that the cost of gears and perhaps a girdle. Yes, the 9 bolt is a 1/4 of an inch bigger, but still. Also, make sure your gears are setup right as that is detrimental to your rear lasting.
Mike
Mike
1 Post
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Also Like to mention that there is an article floating around here about how much stronger the 9 bolt is compared to the 10 bolt, The 9 bolt is listed as being able to handle around 500hp and is stronger than the dana 44.
Also with the 9 bolt, the bearing are pressed onto the axles and are bolted to the housig, wheras the 10 bolt axles are held in place by a clip.I had my axles out before and can't remember the spline count on axles for the 9 bolt, but if I remember correctly, the spline count is less than the spline count on the 10 bolt axles. .
Just wanted to though by thoughts in here.
I have the BW 9 bolt. Pyle Brothers here in my town can't get parts for them or work on them. I have talked with 9bolt.com but they are in Australia? Pyle Brothers told me that no one in the Houston area can get parts for them. Mine is still fine but that raised a few questions for me.
Car: 89 IROC Z28
Engine: 5.7 L Edelbrock perf /holley 3310
Axle/Gears: BW 9 BOLT 3:27
i have an 89 iroc with the bw 9 bolt. do you know who sells a rear end girdle or high strength rear end cover.
www.9bolt.com is the only place I know of that might carry them. Post what you find! It's been awhile since I talked to them.
Car: 1987 Black IROC-Z (SOLD)
With regard to the gear choice, my opinion is that the 3.70/3.73 is a little deep for a TPI/L98 and a 4 speed auto. That first gear is so deep on that trans to begin with, and then you have the short power band with low end torque, plus ONLY 4 gear. I switched from the 2.77 to a 3.27 and when I had the 700r4 I could still easily fry the tires. I've since swapped in a T5 with really tall .068 overdrive, and I still wouldn't want the 3.70/3.73 gear. If the TPI rev'd up another 7 or 800 RPM's it'd be different, but it just quits too early. You need all the time under the curve you can get. You know what they say about opinions though!!!
Car: 1989 iroc z
quick update - i went with the 3.45 gearset, my order made it in 1 week all the way from australia. 9bolt.com girdles $220. i passed on that just cause im dumping a ton on this beautiful machine, gears r in and at the tranny shop as we speak full rebuild, i cant wait to get my baby back.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
a custom built torque converter will complement your upgrades and will make a bigger improvement than the gears.
adding the 3.42s to my crate engine was cool, but the custom 3200 stall was the WOW factor...
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Mike
Mike
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
Hawks carries the girdles for TA Performance
Yukon has gear sets for the 9 bolt too, i believe.
there are alot of places with 9bolts parts! and the bearings and gaskets are avail from many places not to mention the bearings are common sizes lke one is from a 10bolt 7.6 rear ect there is a link "everything I know about 9 bolts" has all sorts of links and info through out the pages
New2Chevy
09-28-2015 12:35 AM
UltRoadWarrior9
09-02-2015 08:24 PM
