series II posi into series III
Car: 1972 GMC
Engine: 355
Axle/Gears: 4:10
I read the 10 bolt sticky (very well done) but still have a question. I have a 91 - 10 bolt 2:73 gear posi and have available to me a 91 - 10 bolt 3:23 open, so I beleive from reading the sticky that I cannot put the posi unit from the series II into the series III.
So I need to get a series III posi or differant gears for the Series II.
Correct.
JC
Correct.
JC
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: series II posi into series III
Why not just switch the entire axles around?
I read that wrong. For some reason when I wrote that I thought you had an open axle and wanted posi.
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
If you have a stock auburn posi it's really not worth putting in especially if you have to buy new gears and set them up just to use your old posi carrier.. You would be much better off buying an Eaton posi for the 3 series gears and your axles. You will be much happier with the outcome instead of going to all the expense and trouble of putting a worn out auburn in.
My stock auburn was worn out in less than 10k miles and no way of rebuilding it. I have an eaton now and it works pretty good for what it is. But the 10 bolt is inherently weak so I'm going to a 9" soon and selling my 3.73 eaton rear.
Car: 1972 GMC
Engine: 355
Axle/Gears: 4:10
What about using a Eaton Locker this guy sells them on ebay/
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
That's an Eaton Governor Lock, not an Eaton Posi. The Gov Lock will not hold up to abuse. I agree that the Auburn is not work reusing. Replacing it with a Eaton Posi or Duragrip would be better.
KO1
16
10-15-2015 05:00 PM
