10 bolt fluid capacity with aluminum girdle
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
I have a 10-bolt with an aluminum girdle installed. What can I expect the fluid capacity to be? Also, I'm running a zexel torsen posi, will I need the GM posi additive? Thanks.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: 10 bolt fluid capacity with aluminum girdle
fill it till it leaks out of the fill hole, no additive needed.
I use the 1 Gallon jugs so I am not sure how many quarts it uses, never really measured.
Car: 1986 IROC-Z
Thanks, much appreciated.
ambainb
04-25-2016 09:21 PM
Navy8125
08-22-2015 07:13 PM
