I hope I didn't make a boo-boo: Just bought a new Differential
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Welp, I just bought a new differential. It's a 9bolt differential out of a supposed 87 Iroc. It does have POSI. The guy said it has moroso 3.42 gears in it with royal purple oil. If it is 3.23s, oh well I'm fine with that. I bought it because it is posi. It came with the rear disk plates that hole the calipers but nothing else. I ended up paying 120 for it.
So my questions are:
This will bolt right up to my 91 camaro I hope? Even though mine is a 10 bolt I believe.
Whats a ball park price for calipers, brake lines and proportional valves run each?
Did I get a good deal?
Any other tips or suggestions?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: I hope I didn't make a boo-boo: Just bought a new Differential
Crap. Below.
The 9- and 10-bolt are interchangeable. The combination valve that would accompany standard disc brakes on an 87 won't bolt to your 91, as the threads are different. However, since the rear doesn't have brakes, you could update to 89-97 PBR's and purchase the appropriate 1LE valve. The second link below is for a 10-bolt, but the only difference is the backing plates (which can be purchased from Ed Miller at http://www.flynbye.com/)
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Other considerations are the speedo drive/driven gears and the parking brake.
JamesC
Engine: 355/350
A 9-bolt will either have 3.27 or 3.45 gears. Unless your 91's rear has been swapped out at some point, the rear is a 10-bolt.
JamesC
JamesC
Would a 10 bolt rear disc set up work on a 9 bolt bw rear?
Car: 87 GTA
The easiest way is to rotate the axle & count the # that the pinion spins. The 3.45 is the 9-bolt equal to the 10-bolt 3.42, so your fine there. And since the 9-bolt 3.27 (the 10-bolt 3.23 equivalent in ratio) is a higher gear, your fine there too since it is a higher gear & you didn't want to go lower.
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Not enough difference between a 3:42 and 3:45 to notice. That 9-bolt is a little stronger than the 10-bolt, but it is hard to find parts for. Rear housings interchange freely between all third gen Camaros & Firebirds, besides the things that JamesC mentioned. Dean
86IROC112
09-07-2015 02:37 PM
red90IROCls1
08-25-2015 07:56 AM
92camaroJoe
08-13-2015 07:07 AM
