If it's not one thing its another. Throwout bearing and pressure plate alignment help
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Well I'm trying to finish this swap but I keep running into problems...
The throw out bearing isn't aligned properly. I have the bigger side of the throwout bearing facing the pressure plate.
Also when not disengaged the throwout bearing has pressure on it cause I can't move it.
Re: If it's not one thing its another. Throwout bearing and pressure plate alignment
Ok just did mine today. I think your problem might be that on the ball that holds your fork in there are two things that go below it. I bet it's just not on there right one of the little clip things might be above and the other below.
Fronzizzle
03-18-2019 09:29 PM
BlackphantomZ28
04-24-2016 09:14 AM
