torsen posi unit help.
i had just bought a torsen posi unit from my local posi guy and was wondering there was any special setup required for this unit. this is gunna be my first rear end install i have a install dvd that is very detailed. just askin for some tips and some tircks. every detail can help. tnx alot.
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
Re: torsen posi unit help.
I installed this unit in my rear end. It's been a year since I did it, but I don't use LSD additive since, from what I was told, the unit has no clutches that need the additive. I just use a synthetic oil. It installs just like any other LSD. Your concern should be with the right contact pattern on the gears.
georgiaslim45
09-09-2015 08:11 PM
