4.10 gears
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: 4.10 gears
If it were only that simple, yes they will fit but you need someone experienced to set that rearend up. I have never seen gears bolt right in! There are some threads on here you should look up regarding this subject!
Car: 89 Camaro RS
Engine: 305 TBI
Re: 4.10 gears
Alright sounds good thanks......so if i took the ring and pinion to a rear-end shop they wouldent be able to install in my stock set up?
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: 4.10 gears
probably going to need a new carrier too depending what gears you have in there now. If you're an RS with an automatic you've probably got 2.73's, so you'd need a new carrier. Don't forget a shim kit either.
Re: 4.10 gears
Depends what " type " gears they are.
There are two kind I heard of, but don't recall how to tell them apart.
There is a " series 2 carrier " & a " series 3 carrier ".
Maybe another, but I can't remember.
See if you can find the number that was cast into the rear end somewhere.
The gurus will be able to help you.
Re: 4.10 gears
If you have 3.23 to 3.73 gears in it now then you have a 3 series differential, and the 4.10 will work on it. If you have 3.08 to 2.41 gears now then you have a 2 series differential and the 4.10 gears will not work, unless you have the special after market gears that have a thicker ring gear that is made to fit the 2 series.
Hotrodboba400
12-10-2019 07:07 PM
UltRoadWarrior9
09-02-2015 08:24 PM
