Gears from third gen 10 bolt into 4th gen 10 bolt
Re: Gears from third gen 10 bolt into 4th gen 10 bolt
Yes you can. Just be sure that the differential is the correct series for the gears. If you are swapping the differential too then be sure that the axle splines are the same.
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
just to refresh your memory, 82-89 is 26 splines whereas 89/90-up have 28 splines axle shafts and a corresponding differential carrier. i'm sure you're also aware of series 2 versus series 3 carriers, and that the 4th gen rear is wider thanthat of a 3rd gen (iirc also means you can't swap axles between those).
hectre13
12-11-2023 08:14 AM
355tpipickup
08-25-2015 12:54 AM
