Crossmember bolt holes stripped
Ive had my crossmember spot welded in for the past few years. Im pulling my trans out this weekend, im wondering what the bolt and thread size is so I can replace one bolt thats missing and heli coil the holes that are stripped out. Anyone know these sizes?
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: Crossmember bolt holes stripped
The bolts are metric - M10 x 1.5 x 32. I had one strip out, but instead of using a helicoil, I tapped the stripped hole using a 7/16-14 tap (slightly larger than the M10), then used a standard bolt.
evilstuie
01-09-2020 08:29 PM
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
