How do i get more gear out of my truck??
I have an 84 Chevy Scottsdale pick up truck that ive been rebuilding. It has a 3 speed manual trans in it. This truck is NOT meant for the highway. If i get over 55mph im turning some serious rpm's. What can i do to change that? Is it as simple as swapping out the ring and pinion? Thanks for any help
Car: 1989 C4
Axle/Gears: 307
Re: How do i get more gear out of my truck??
Well it just depends on what ya got now. Ive got a 76 short box, 3 speed manual trans and 373's in it. Highway isnt to bad only 3k at 75 mph. Your trans should have a 1:00 final ratio so they only option your would have is an overdrive trans or a different rear end ratio. Most trucks of the smog eara were 3.08 rear axle trucks so if you wanted to step down you can usually pickup a whole axle for $200 no need to mess with a gear swap but I suggest seeing what you have in the truck now before you make any decision.
ok thanks ssc, i'll do that....sorry to waste your time joe, i joined here to get advice on my truck project, not to get smartass answers.
Car: 1989 C4
Axle/Gears: 307
No problem, Seems like like you might be better off @ http://67-72chevytrucks.com/. I have an account there and more then just 67-72 trucks are covered all GM trucks of all years are covered.
http://www.hotrodders.com/forum/transmission-rearend/ Here is another that you might try.
Hotrodboba400
12-10-2019 07:07 PM
UltRoadWarrior9
09-02-2015 08:24 PM
