TH 400 dimensions
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
TH 400 dimensions
How much shorter is the TH 400 transmission with a 4" tailshaft than a 700r4. Im doing a swap
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: TH 400 dimensions
Found this link. It may help you.
http://www.tciauto.com/Products/TechInfo/trans_dims.asp
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
what measurement do you want off the 400? I have one in my shop I will get the measurement in the morning if that would work.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
ok I will post them in the morning I am replacing 700r with th400 also. I want to say the mount is 5 1/2 inches diff. but will let you know for sure.
Engine: 406
The crossmembers they sell are for one with a 4" tailhousing, is that what you have. The TCI website says well there are 2 different measurements, 28 3/8 or 33 27/32. The 700r4 is 30 3/4
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
ok the overall measurement for th400 with 4" tail housing is 28 3/8" and the mount is 26 7/8" from engine just like the post by Built 91z28 but I never could find that out when I was making up my crossmember supports.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
This is my cross member bracket that I made. TH400.
Sorry, I can't get the picture to come up.
Hotrodboba400
12-10-2019 07:07 PM
88SS6SPEED
11-11-2015 07:05 AM
1984, 400, 84, camaro, detailed, dimension, dimensiond, dimensions, length, messurements, mount, mounting, slipping, th400, transmission
