Th 400 TV Cable help..
Car: 84 Trans am
Engine: 355
Transmission: TH400
Axle/Gears: 343 rear end
now, im very new to automatic trannys and have a th 400.. what i need to know is about the kickdown cable/ Throttle valve cable if absolutely need it to move or if i can rig it somehow so i can still go? btw its an older rebuilt th400.. like '85
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Th 400 TV Cable help..
You'll need the cable to automatically downshift when you step on the gas, but it's not as critical to the operation of the transmission like a 700R4 TV cable is.
Engine: 383 Carb
Transmission: 4L60
That's right, when i read cable I started thinking of the TH350. The TH400 uses an electric kickdown switch.
TMZIrocZ350
10-07-2015 12:09 PM
