torq lock up kit question
Car: 1992 Camaro Z28
Axle/Gears: factory 373
ok i went carb with no ecu on my 92 camaro. i have a 700r4 tranny and i know i needed the tranny lock up kit. so i got the TCI one for around 80 bucks...ok so im pretty sure i hooked up up right, and i have the vacume going into my manafold...also i turn it on with a mallory switch box...the only problem is everytime i flip the switch, the fuse blows right away. i tryed up to a 30 watt fuse?....
so the question is...what size fuse?
or did i do somthing wrong. please help/.
Re: torq lock up kit question
what could i have done wrong, could it be the ground? or no
Last edited by defaria27; 03-09-2010 at 12:35 PM. Reason: could it be the ground or no?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'll have to check your wiring. Chances are you've got +12v going directly to ground somewhere.
Car: 89 Camaro RS
Engine: Carb'd 350
Axle/Gears: 3.70
Heres a link to the instructions for the Universal TCC Lock-Up Kit for 700R4 and 2004R
http://static.summitracing.com/globa...tci-376600.pdf
Its says: Using 18-gauge wire, run a 12-volt source to the red
wire on the external harness (Terminal A).
so were would i hook up that wire, it coulnt go stright the battery, i would splice it into the pink igntion wire?>
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yes - you need to connect the red wire to any wire that is switched (has power only after ignition is on).
You can run a manual switch to manually engage the lockup whenever you want by running the GREEN wire to one side of a switch, and connecting the otherside to a ground. When you turn on the switch, the green wire gets grounded and locks the converter.
One thing - be very very very careful with that vacuum line nipple on that little POS vacuum switch they provide - mine broke the first time I pulled the vacuum wire off, and a replacement vacuum switch is mucho $$$. I just trashed mine, and I only use the manual switch to lock mine up on the highway.
ok im not going to hook up the green wire...but for the red...what did u hook yours up too? what wire would u suggest to splice it into?
Car: 1992 RS
Engine: Carbed 350
You should have plenty of leftovers that were hot-in-run - maybe an injector wire or something? The TC lockup function doesn't require alot of juice, just 12v to activate.
Engine: 383 Carb
Transmission: 4L60
The "gauges" power circuit is where the factory powered the TCC solenoid from.
LT1Formula
11-16-2015 01:13 PM
