Can someone tell me what these 700r4 parts are?
Car: 1989 Chevy Corvette
Engine: 383 SuperRam 10.7 AFR 195 220/229
Transmission: Fancy Smansy 87 Corvette 700r4
Axle/Gears: 3.33
If they are complete, and what they are worth? some of the stuff was installed never driven and removed, any comments would help and thanks!
700r4 parts
http://i679.photobucket.com/albums/vv159/Salsadancer383/CIMG0463.jpg
http://i679.photobucket.com/albums/vv159/Salsadancer383/CIMG0464.jpg]
[IMG]http://i679.photobucket.com/albums/vv159/Salsadancer383/CIMG0465.jpg[/IMG]
[IMG]http://i679.photobucket.com/albums/vv159/Salsadancer383/CIMG0466.jpg[/IMG]
[IMG]http://i679.photobucket.com/albums/vv159/Salsadancer383/CIMG0467.jpg[/IMG]
[IMG]http://i679.photobucket.com/albums/vv159/Salsadancer383/CIMG0468.jpg[/IMG]
[IMG]http://i679.photobucket.com/albums/vv159/Salsadancer383/CIMG0469.jpg[/IMG]
[IMG]http://i679.photobucket.com/albums/vv159/Salsadancer383/CIMG0470.jpg[/IMG]
[IMG]http://i679.photobucket.com/albums/vv159/Salsadancer383/CIMG0471.jpg[/IMG]
700r4 parts
Car: 1991 Camaro Z28
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
Re: Can someone tell me what these 700r4 parts are?
your links are no good
The parts that I see are the overrun, forward, and 3-4 apply pistons for a 700R4 with seals. The low/reverse planetary. A Superior 2nd apply servo. A Sonnax 4th apply servo. The Superior 2nd apply servo I would not use except for "race only". The Sonnax 4th apply servo is ok if you are going to make 3-4 WOT shifts. The overrun, forward, and 3-4 apply pistons with seals are stock, which is fine. The last picture is a low/reverse roller clutch. What is it you want to know here?
Axle/Gears: 3.33
The parts that I see are the overrun, forward, and 3-4 apply pistons for a 700R4 with seals. The low/reverse planetary. A Superior 2nd apply servo. A Sonnax 4th apply servo. The Superior 2nd apply servo I would not use except for "race only". The Sonnax 4th apply servo is ok if you are going to make 3-4 WOT shifts. The overrun, forward, and 3-4 apply pistons with seals are stock, which is fine. What is it you want to know here?
Take the IMG and the encapsulement off of each end of the URL. The pistons are in every 700R4. The Sonnax and the Superior servos are used. They are worth about $100.00 at the most for both. The low/reverse planentary, looks like a China version. It's worth is $0.00.
LT1Formula
20
11-14-2015 12:02 AM
