88 posi unit 10 bolt chunk swap
1 Post
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: 88 posi unit 10 bolt chunk swap
As far as I know yes as long as there both 10 bolts with the same number of splines. If the 88 has the 28 spline carrier you would also have to use it's axles. I'm sure someone will chime in who knows more about it then me.
Good luck!
Mark.
Good luck!
Mark.
The 28-spline axles didn't appear until 90, though a few may have crept in in late 89. The answer is yes, the 88 will swap to the 85. General info follows:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
JamesC
Be sure that it is the right series for the gears that you are using. The 7.5 10 bolt uses a 2 series for the 3.08 to 2.41 gears and a 3 series for 3.23 to 4.10 gears. You can't use a 3 series with 2 series gears...
http://www.nastyz28.com/forum/showth...ht=change+posi
Read this.
Read this.
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
knight72
08-10-2015 09:32 PM
1992 Trans Am
08-08-2015 08:16 PM
