Detent Cable Bent??
Detent Cable Bent??
Hey guys, I have a little problem and I am not sure at how to fix it. I took one trans out of a junk 86 Camaro to put into an 87 one. They are both automatic and the "good one" ran fine on the ride home. But taking it out we forgot to disconnect the detent cable, so it was basically hanging from the cable. we eventually just cut the cable (because we didn't know how to take it off properly). Now we put it in and it doesn't shift right. Is it possible that we bent the detent cable. And yes we tried to adjust it.
Thanks Chris
Thanks Chris
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Detent Cable Bent??
Not really, the cable jacket should have taken any strain. What's it doing that makes you say it's not shifting right?
Engine: 383 Carb
Transmission: 4L60
So... you've put the "good" transmission into the "good" car, with a cut and disconnected TV cable?
We removed the cut tv cable from the good trans and hooked the good trans up in the good camaro with its tv cable.
All I really need to know is can I bend what the tv cable connects to into the trans??? And if so what does it take to fix?
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
are you saying you applied pressure on the hook inside the transmission?
Engine: 5.1 4bbl
well if that's the case, then your best bet would be to head on over to a junk yard and pull off the part you need... I would first take the old tranny's pan off and play around to see what actually has to come out in order to get what you need... straightening the hook is not going to be an option in this occasion....
Engine: 5.1 4bbl
Ok now I feel like a dork... lol... you already have a bad tranny, do you still have it, the one you took off... just take whatever you need from that one, unless it's damaged as well....
TMZIrocZ350
10-07-2015 12:09 PM
