Do you guys drive in D or OD?
I'm just curious to know what is the best way to drive around locally. I normally drive in D and upshift to OD when i hit the highway. I notice a difference when i stomp on it in D. It seems more aggressive performance wise than in OD, at least it feels that way. How do you guys drive locally? Does it make a difference? This is my first car with OD and i'm not sure if it really makes any difference whether or not i just leave it in drive all of the time.
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
Re: Do you guys drive in D or OD?
not true. third gear is 1:1 and OD is .70, so there will be the feeling of more torque just because of gear multiplication. and as far as the rest, th350 and 400 transmissions have been used in cars forever, they have 1:1 top gears and have reputations for lasting. that said it probably kills a few mpg leaving it it d vs od, so i'd leave it in OD.
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
OD is 4th gear and it lets the car roll free wenn off trottle in all gears.
Your statement is correct if driving at high speeds, eccept the "not true". Dont know if you noticed but the OP shifts in to OD at US highway speeds and he talks about stomping. No mather if in 3 or 4, the transmission will downshift in 1 or 2 wenn stomped, in his specified situation.
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i always leave it in drive and i only put it in overdrive when im on the highway.... i have a probuilt 700r4 with a 2200 stall if that matters...
86IROC112
08-17-2015 02:00 PM
