9 bolt horsepower?
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: 9 bolt horsepower?
if i remember correctly i read an article where it said that the nine bolt for our cars were rated at 290hp and 320tq.. i know the numbers are really close to what i said... if you add a performance girdle with studs from TA performance that nine bolt will be 25 percent stronger so it will up the rating to 362hp and 380tq.... again im not totally sure about the numbers... but people having been running way higher numbers than those and the nine bolt holds up for them... so im not really sure...
depends on tires, if it doesn't hook it won't break.
yeah with that horsepower you need a upgraded rear end like moser or dana...... the stock one will not last.... i say the nine bolt is perfect for a mild build 350.... plus parts are alot harder to come by with the nine bolt....
Saxondale
Exterior Parts Wanted
09-07-2015 07:11 PM
UltRoadWarrior9
09-02-2015 09:24 PM
