T5 swap to TH400... crossmember/torque help please.
Car: 1987 Camaro IROC-Z
Engine: 406 sbc
Transmission: T5 for as long as it holds together
Axle/Gears: Limited Slip.. 3.08
i have a 1987 IROC, the tnew tranny in and bolted up. cooler and Lines are in. I think I can use some custom fabricated spacers and longer bolts in order to use the stock crossmember. Thats still being worked out, however im at a totall loss of what to do with that torque arm. Any ideas or soloutions would be of help. Thank you.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: T5 swap to TH400... crossmember/torque help please.
an aftermarket crossmember mounted torque arem setup would be good. Check UMI performance, Spohn, or BMR fabrication.
Hello, we offer a torque arm relocation crossmember for your swap or if you have a short torque arm a transmission crossmember. Here are some pics of both crossmembers. If you have any questions or would like one let me know.
Car: 1986 Camaro
Engine: 350 v8
Axle/Gears: 10 bolt,disks, 3.23 posi rear
ok im lost can someone give me a link to spohns th400 crossmember with mouth for stock torque arm?
or do they not make one?
I got mine from UMI for a TH400 bolted to a big block. Factory torque arm bolts right up. Comes in red or black. $239.00 bucks.
this is how i mounted my th400, it always worked great, no clearance issues or anything and it seemed to plant the rear just a bit harder, its not like spohns but it was nice
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
They dont make them. All their conversion crossmembers are made to be used with their torque arms. I can say that they are very nice pieces though. The only problem with mine is that it runs right where I need to put my exhaust so I am going to fabricate a new crossmember that will still use the Spohn torque arm.
87, 91, camaro, crossmember, crossmenber, firebird, gen, install, installing, iroc, sbc, swap, t5, th400, tremec
