Transgo shift kit in a 700R4
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
I have a 700r4 in an 89 iroc with 350 hp carb setup. Motor and trans have 600 miles on them. I know there are a lot of topics on transgo on here. Is there more than one trango shift kit sold for my car. I found one that was 104 bucks and it came with the corvetter servo. My friend has installed one before and I havent. Any advice do's and donts or opinions on the transgo kit.Tranny shifts like stock now, Im looking for a much firmer shift especially when on the gas. Thanks much
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Re: Transgo shift kit in a 700R4
There are two kits you can choose from, I suggest the SK700...when I rebuilt my 700 I used the SK700 kit, it was like night and day in the firmness of the shifts...it takes some getting used to though... and I do have a weird thing going on, when in coming out of 1st (shifter in OD) I almost get a "false" shift or it seems like a false shift for a split second, then it will shift into 2nd...doesn't do it when in D, or at WOT (in either D or OD)... it has been something that I have lived with for over 6 years now without any issue but it was definitely a result of the tranny upgrade (but when I re-did my transmission I did a full on race upgrade, upgraded every single piece so it could be a symptom of something other than the shift kit)...
SK®700 THM 700R4 81-up
Corrects/Prevents/Reduces: Absolutely prevents Stuck TV valve. Late shifts, downshift clunk; 3-4 clutch failure; no lockup; 2-4 band failure; early shifts; 1-2 slide/slide-bump; reverse delay hot; 2-3 cutloose;
reverse clutch failure. 83-87:
Kit lets you make Converter lockup-no wires needed.
SK®700-Jr THM 700R4 85-up
Corrects/Prevents/Reduces: FIXES late shifts - Sticking TV Valve. 3-4 clutch failure; soft or slide-bump 1-2; 2-3 cutloose; shuttle 4-3-4-3; soft or late 4th.
FAST- Easy installation!
It should but maybe you could call Transgo directly and ask them to be 100% sure....
But maybe someone here can answer that question directly through personal experience, my 700 has a lock up convertor
http://www.transgo.com/contact.php
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
was it difficult to put in? any advice. Im looking at the one by pro-built automatics and it comes with the corvette servo. Mine just seems real sluggish. Also, can you guys give me the shift points where they should be. I have a 700r4 with a non-lockup converter. My shift points are gear 1-2 at 20, 2-3 at 30 and 3-4 at 40 or 45. Does this seem right. MY dads 87 corvette tpi with a 700r4 shifts from 1-2 at 12-14 and his tranny feels better than mine all around. Mine was just rebuilt 600 miles ago. Thanks for any input.
I used the trans go shift kit about 3 years ago and it's great. I started with the stage 2 but then swapped the 1-2 spring out for the stage 1 cuz i didn't really want it shifting super hard, just tight. It came with really good instructions and was pretty self explanatory to install.
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
Great guys, thanks for the advice. I called Dan from Pro-built automatics. He was more than helpful!! He set me up a kit and should be here soon. I will let you know how it goes.
Car: 1986 Trans Am
Engine: LG4 305 carb
Transmission: auto 700R4
Axle/Gears: 2.73 open
I have a TransGo kit in my Trailblazer which has a similar transmission to the 700R4. I had my local shop in stall the shiftkit, vette servo, and .500 boost valve for $200. It makes a big improvement. Firm shifts during regular driving and at WOT the 6300lb Trailblazer now spins into second gear. I'm in the process of getting the same parts for a rebuild of my 700R4 in the Trans Am.
~Matt
~Matt
Hotrodboba400
12-10-2019 07:07 PM
tonys91rs
10-10-2015 03:31 PM
TheTraut88
09-07-2015 05:22 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
