t5 vs 56 crossmembers
1 Post
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: t5 vs 56 crossmembers
the t56 is further back. If you're putting in a T56 in your thirdgen....then you need like a spohn T56 adapter crossmember.
1 Post
Engine: L98 494hp
well the t5 torque arm is the same as the t56 one. so you wouldn't need to make a new crossmember. Is the 9 inch setup to accept a torque arm?? if not then you'll have to adapt it.
1 Post
Engine: L98 494hp
oh, yeah you would....I've seen people modify factory t5 crossmembers for t56, so you could modifly that one to probably....they dont sell one for a t56??
1 Post
Engine: L98 494hp
I don't know either.....worth researching though. Maybe someone else will chime in here and inform us both, lol.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
kammi10
11-09-2015 08:28 PM
tmork454
09-29-2015 06:33 PM
TOMcat GTA
09-15-2015 09:31 AM
arm, camaro, compatable, crossmember, difference, differences, modify, mount, spohn, t5, t56, torque, transmission
