T56 swap cross member, DIY
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Well, here is the piece i made today, works well. I only have a 110 amp flux core welder, so i welded more than you would if you had a 220 amp.
I call it the "Spawn" cross member. Since it is spawned from the stocker. LOL
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: T56 swap cross member, DIY
Well, the good welds are under the bad ones, i ran out of wire and used my buddys, his was a POS, so i did what i could. It is just a 305, but it is solid, i dropped it, kicked it, put weight on it, should be ok. That is why i have a spohn for my hard top and the big block.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, beat the hell out of it and it is holding great. But this is a carbed TBI 305. I might be lucky to have 200 HP. Keeps pulling with the performer RPM and carb compared to the TBI junk i removed.
Z
Z
1992 Trans Am
08-08-2015 08:16 PM
3rd, cross, crossmember, crossmembers, diy, engine, fbody, gen, generation, member, members, spawn, swap, t5, t56
