Production T-56 GM part numbers?
1 Post
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Does anybody have GM part numbers for the following:
1)bell housing
2)hydrolic clutch assembly
3)Transmission, 93-97 F-Body
4)clutch fork
5)flywheel
6)bolts:tranny to belhousing, pressure plate to flywheel.
'91 Formula
383CI Superram, Sportman II's
SLP Cam 214/224 .470/.490
Vortech V1 S-Trim with custom 8 rib pullies
5-speed
3.42
12.34@117.04, 1.91 60Ft.
on Drag Radials
1)bell housing
4)clutch fork
5)flywheel
'91 Formula
5-speed
3.42
on Drag Radials
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I've got most of these lying around, let me see what I can find.
10222083: LT4 Pressure plate
12523315: Aluminum spacer for slave cylinder
I've got the rest at home; I'll check if I remember.
1 Post
Got any other Numbers?
'91 Formula
5-speed
3.42
on Drag Radials
'91 Formula
5-speed
3.42
on Drag Radials
1 Post
Somebody?
'91 Formula
5-speed
3.42
on Drag Radials
'91 Formula
5-speed
3.42
on Drag Radials
1 Post
Thats ok guys. I am getting a Tremec TKO instead.
'91 Formula
5-speed
3.42
on Drag Radials
'91 Formula
5-speed
3.42
on Drag Radials
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Why not just buy the aftermarket T-56 from SDPC2000. It's $1950 and will go into your car cheaper than a TKO
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Tremec TKO
Pro 5.0 Shifter
GM posi 3.42 rear
Hurst Roll Control
13.9@102
http://www.geocities.com/thetpiguy/index.html
chemjoker@aol.com
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Flowmaster Exhaust
Tremec TKO
Pro 5.0 Shifter
GM posi 3.42 rear
Hurst Roll Control
13.9@102
chemjoker@aol.com
1 Post
I don't want to shorten my torque arm or drive shaft.
'91 Formula
5-speed
3.42
on Drag Radials
'91 Formula
5-speed
3.42
on Drag Radials
Car: 1968 Camaro
Engine: 406
You will need to if you buy a TKO, plus U-joints for a new yoke (Ford=31 spline). No torque arm mount on a TKO. A crossmember is produced to accept your torque arm mount, mount a t-56, and I really dont know if you need to cut your DS if you buy an aftermarket.
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Flowmaster Exhaust
Tremec TKO
Pro 5.0 Shifter
GM posi 3.42 rear
Hurst Roll Control
13.9@102
chemjoker@aol.com
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Flowmaster Exhaust
Tremec TKO
Pro 5.0 Shifter
GM posi 3.42 rear
Hurst Roll Control
13.9@102
chemjoker@aol.com
1 Post
TPI GUY... where did you get your Tremec From? I thought it came with a torque arm mount? I also thought the stock driveshaft would work, once you change the slip yoke.
Car: 1968 Camaro
Engine: 406
I got my TKO from Forte's. It was drilled for a standard bellhousing to fit my 1973 Nova (see link to webpage).
Here is what I know:
No stock Torque arm provisions, however, it will fit with an adapter:
http://www.fortesparts.com/tremec/tr...6firebird.html
Torque arm bracket (82-92 F-body) $80
More details here:
http://www.fortesparts.com/tremec/tr3550-2.html
More details here:
1 Post
Great thanks for the information. I guess I'll give Fortes a call.
1992 Trans Am
05-10-2023 07:19 PM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
IrocZ'85
08-17-2015 06:24 PM
