700r4 sensor/plug? what is it
Car: 1989 Firebird
Transmission: 700r4 w/ kit
i just swapped 700r4 and there is a plug with two prongs on my old one. it is located in the rear of the tranny, driverside, near the torque arm. the 700r4 that i replaced it with does not have a plug, it has a small threaded shaft on it in the exact spot. i have no idea what either of these are for... and the plug from the old tranny does not fit the new one. any ideas???
Re: 700r4 sensor/plug? what is it
The electrical terminal on you old transmission is for your vehicle speed sensor to operate your electrical speedometer...
The threaded connector on your new transmission is for a speedometer cable to operate a mechanical speedometer
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
700r4, connection, connections, electrical, eletrical, plug, plugs, pulg, sensor, speed, speedometer, speedos, transmission, wire, work
