The transmission leak from hell
Old 12-05-2001 | 10:07 PM
MotorCityMuscle's Avatar
When the transmission mechanic installed my transmission, he neglected to hook up the TV cable. i did not realize this until I poured in 5 quarts of fluid. Needless to say it went all over the ground. I had to attempt to hook up the TV cable from under the car. I finally got it and poured in a bit of fluid, but it promptly strted leaking again. Is there a seal around where the TV cable enters the transmission? Why won' this thing stop leaking after its been tightened down? TIA.
Old 12-05-2001 | 10:15 PM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
Yes, there is a seal that goes in between, I forgot to put it back in once and that did make a large mess.
Old 12-05-2001 | 10:29 PM
Can I buy this seal or could I just use RTV or....?
Old 12-05-2001 | 11:07 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
No RTV!!!!!!!! Go get you a seal!
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
AussiePr0nCar
03-06-2020 05:04 PM
LittleFranks
09-17-2015 01:22 PM
angel2794
09-08-2015 07:22 PM
formula_novice
08-18-2015 09:48 PM
mizz0313
08-12-2015 07:45 AM
