T-5 Hydraulics used for LT1 T-56 swap
Car: 1984 Trans Am
Engine: 383 4 bbl
Axle/Gears: eaton posi w/ 4.11's
Can i use the hydraulics(master,slave cylinder) from a T-5 for a T-56 swap?
Car: 1984 Trans Am
Engine: 383 4 bbl
Re: T-5 Hydraulics used for LT1 T-56 swap
damn, and thank you
the master is the same internally but the hole in the pushrod for the pedels is a diffrent size the slave has a diffrent amount of through and hose is alot longer and braided, I used a T-5 master, a custom hose W/O the restrictor and an aftermarket slave
rsrmoore
08-07-2015 08:44 PM
