Axel shaft prop... Help please..
Car: 91 B4C 92 Z 93LT1
Engine: L98s & LT1s
Transmission: 700R4s all around
Axle/Gears: 3.23x2 & 3.73
I'm at a loss here.. I have a 92 3.23 disc car.. I need a pass side axel shaft which the dealer says is discontued, this is a g92 car.. I've tried axels out of every 28 spline car i come across, the difference is my g92 car has a larger diameter shaft than any other car i've seen.. Is this axel only 90 to 92 G92 cars or am i missing something here. does anyone know the interchange or where to get what i need? summit and jegs seem clueless as to a difference in shaft diameter.. anything you think will help.. thanks guys
Car: 1987 Black IROC-Z (SOLD)
Re: Axel shaft prop... Help please..
RPO G92 option has nothing to do with the dia of the axle shafts.
All 90-92 3rd gen cars have the same dia & spline count...short reply they are all the SAME. You have other problems in my opinion.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The 90-92 third gen axles are the only ones that length. You can buy aftermarket 28 spline axles which are much better than factory ones for around $125 each. Places like Moser or www.tomsdifferentials.com carry them.
dbrochard
10-03-2015 12:43 PM
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
