How can I tell if I really have a 3.73 rear??
Old 11-17-2001 | 01:30 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
This is a 10-bolt rear end. How many teeth should the ring gear have? How many turns of the pinion to 1 turn of the ring?
Old 11-17-2001 | 04:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
OK, this is going to seem really complicated, but... if you have 3.73 gears, the pinion will turn 3.73 times for each rotation of the wheels.
The most certain way to tell what gears you have is to pop the cover off and look. Factory gears have the teeth count stapmped in the edge of the ring gear. 3.73 will be 11 & 41. Doesn't matter what kind of rear it is, numbers are numbers. Since gears can only have whole numbers of teeth, the ratios are always 2 whole numbers; usually at least one of them is a prime number. 3.42 is 12 and 41, 3.08 is 12 and 37, 4.10 is 10 and 41, 2.73 is 15 and 41, etc.
ICON Motorsports
Old 11-19-2001 | 05:18 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
if the gear is factory, it should be RPO GT4
84 Z28 L69. 5 speed with 3.73 posi (broken)Ported heads, intake, 10:1 comp. 230/230 .480 lift cam @.050" w/108 LSA
Triumph Spitfire SCCA roadracer. 1.1 liter 4cyl w/ 14:1 comp.
Outcorners anything!
Old 11-19-2001 | 06:16 PM
MouseCamaro305's Avatar
if you have a 700 r 4 trans you can get onto the highway, bring it up to 75 MPH and keep it in D rather than OD, your tach should read out 3,730 RPMs.
Old 11-19-2001 | 07:43 PM
Car: 1992 Camaro
Engine: 350 miniram
Well RB83L69 was correct in saying that if they were GM gears, the ratio would be stamped on the ring gear. It turns out that the rear is actually a 3.42 ratio. This rear was behind a TH-350 and the rpms were around 3250 at 65 which I though was real high, and to find out they are only 3.42, I would hate to see what driving with 3.73s must be like.
Old 11-20-2001 | 02:19 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
3:73's aren't that bad... sure i have some strange vibration at 80 MPH since i installed the rear but the get up and go.. especially now that its cooler out is AMAZING! When i don't have my lead shoes on i can still get the same MPG that the 2:73's had ok, ok, so that doesn't happen very often.. but it does happen!
  • 89 Formula 305 WS6
    All the usual suspension mods
    Custom Flowmaster Exhaust
    Tranny Cooler
    Dual gauge pod
    Most "Free" Mods
    3:73, Zexel Torsion Posi
    15.559 @ 88 MPH
    (Not good enough)
Old 11-20-2001 | 03:55 PM
a73camaro's Avatar
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
Never noticed that before, the prime number thing...
[This message has been edited by a73camaro (edited November 20, 2001).]
Old 11-20-2001 | 04:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yeah, they use prime numbers as much as possible, because that way every pinion tooth contacts every ring tooth, and no combination of mating teeth repeats itself more often than any other combination. Helps spread the wear as eveny as possible, keeps it as quiet as possible, etc.
ICON Motorsports
Old 11-20-2001 | 07:20 PM
Momar's Avatar
does anyone know how many teeth the gears for the 9 bolt 2.77 have. Is the 9 bolt 3.08 the same as the 10 bolt. What I was wondering is: I have 2.77s in the rear that is in my car. I have another in my garage with 3.08s. Would it be possible to use the ring gear from one and the pinion gear from the other to get lower ratio gears than are normally offered for a series 2 carrier on a 9 bolt.
Ben
Old 11-22-2001 | 08:58 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula, '95 Formula
Engine: LC9 , LT1
Transmission: TKX , 4L60E
Axle/Gears: 3.50 9" , 3.23 10bolt
I was always under the impression that the driveshaft method works. I.e, how many times the drive shaft spins vs a single tire spin.
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters,
Summit 1.5 roller rockers, World Products Sportsman II 2.02/1.60 heads, Edelbrock TPI Intake,
Cloyes Double Roller, timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs gauge, A/F ratio gauge.
http://www.joesperformance.com
Old 11-22-2001 | 11:21 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by Omega:
</font>
And how's the tire situation with them, bald yet?
3200 is right on for 3:42's and a tb 350.
SSC
Old 11-23-2001 | 12:23 AM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
The only way to be sure is to jack up your car ...make the wheel spin and look in the side of the ring if its a 3.73s it should look like this " 41 11 " if you divide 41/11 you have 3.73 that means 3.73 driveshaft turns per one on the tire
Old 11-23-2001 | 12:25 AM
Calderone's Avatar
Car: 87 Vette
it means 41 theet on the ring and 11 on the pinion
thats it
hectre13
12-11-2023 09:14 AM
89fast5oh
08-24-2015 09:14 AM
Zeek1041
Theoretical and Street Racing
08-21-2015 09:45 PM
Dialed_In
08-20-2015 02:45 PM
