one pc. rear bolt on M5 trans
hello everyone I have a 1987 camaro z28 with a borg/warner T5 transmission in it and i took out the stock GM 5.0 L and want to replace it with a GM 5.7 which is a one piece rear main seal and the 5.0 is a two piece is there an adapter or some way that i can install the T5 trans on the 5.7??? PLZ HELP. thank you
Re: one pc. rear bolt on M5 trans
JamesC
My friend told me that i can also use a flywheel off an 85 or older GM block and it willl work for a one-piece crank seal is he right??...
You should be able to reuse the flywheel from your 87.
JamesC
the bolt pattern and dia. is a little different i dont think it will match up the 350 block which was attached to a 700R4 is a one-piece rear main seal and the 305 which was attached to the M5 is a two piece rear main seal I need a different Flywheel dont I???? and what type??
JamesC
Car: 87 GTA
