Most reputable tranny companies
I am going to need an automatic tranny that can handle up to 1000HP. While I'd like to have OD, i just do not see that happening. So, I am most likely going with the TH-350 or TH-400 ; probably TH-400. What are some of the more reputable tranny companies that can provide these trannies, able to handle that much HP, without requiring me to sell my kidney. Assume that sufficient mods with be done to the car - 1985 IROC - to insure that i can get traction.
EDIT - It must be an auto, because this is going to be connected to a turbo motor. I'll need to leave the line with boost, so i'll need load on the engine, and a manual with a stutterbox will probably be too expensive.
[This message has been edited by True Power (edited November 14, 2001).]
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Assuming this is a track-only car, consider a Powerglide. You can build one of them from scratch with all after-market parts.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2200 stall TC. Ported World 305 heads, Crane PowerMax cam. ZZ4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster. 2.93 limited slip, Spohn SFCs. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
It's not a track-only car; mostly track, yes, but I will take it out on the street every now and then. I don't intend to hit 1000 horsepower, I just put that figure there so that I don't underaim
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
